Important Problem after upgrading
15 years 9 months ago - 15 years 9 months ago #86080 by DemoneBianco
Since I upgraded to version 1.6.3 I have several problems with my forum in the module joomla. Errors are indexing the pages, makes it impossible to edit profiles, errors of various redirects. Some things I resolved by moving the post in the new sections, but still many problems in it. Please how can I normalize everything?
Sorry for the language, but I'm Italian and I used the google translator to expedite communication.
Have increased the problems now, for no apparent reason, does not make me more access to the sections that I have this error message:
This page is not redirecting properly
Firefox has detected that the server is redirecting the request for this page so that it can never be completed.
* This problem is often caused by the blocking or rejection of cookies.
I enclose also the site code:
Legacy mode: Enabled | Joomla! SEF: Enabled | Joomla! SEF rewrite: Enabled | FTP layer: Disabled |
htaccess: Exists | PHP environment: Max execution time: 120 seconds | Max execution memory: 64M | Max file upload: 25M
Joomla default template details : ja_purity | author: JoomlArt.com | version: 1.2.0 | creationdate: 12/26/07
Third-party SEF components: sh404sef: Disabled or not installed | ARTIO JoomSEF: Installed (Version : 3.7.6) | AceSEF: Disabled or not installed
Plugins: System - Mootools12: Disabled | System - Mootools Upgrade: Disabled | JFirePHP: Enabled (Version : 1.0.1) | Kunena Discuss: Enabled (Version : 1.6.2) | Kunena Search: Enabled (Version : 1.6.2) | My Kunena Forum Menu: Enabled (Version : 1.6.2) | My Kunena Forum Posts: Enabled (Version : 1.6.0-RC1)
Modules: Kunena Latest: Enabled (Version : 1.6.2) | Kunena Stats: Enabled (Version : 1.6.2) | Kunena Login: Enabled (Version : 1.6.2)
Last edit: 15 years 9 months ago by DemoneBianco. Reason: More problem
15 years 9 months ago #86097 by tinetto
Replied by tinetto on topic Re: Problem after upgrading
delete all menu pointing to kunena
also in the trash
after that click the Create Menu button in the Kunena backend
see
www.kunena.org/forum/159-k-16-common-que...it=10&start=40#83549
15 years 9 months ago - 15 years 9 months ago #86099 by DemoneBianco
Sorry but it does not work. For example, if I click on "profile" we are very load and then the usual error. I also reinstalled Kunena 1.6.3, but the same problems
15 years 9 months ago #86122 by xillibit
Please disable legacy mode and try to use default sef system provided by Joomla! insteado f artio sef.
15 years 9 months ago - 15 years 9 months ago #86127 by DemoneBianco
yes and now, notr find my site!
Home
Direct Access to this location is not allowed.
Paste my .htaccess - the provider is Aruba andi joomla is in the root
# @version $Id: htaccess.txt 10492 2008-07-02 06:38:28Z ircmaxell $
# @package Joomla
# @copyright Copyright (C) 2005 - 2008 Open Source Matters. All rights reserved.
# @license www.gnu.org/copyleft/gpl.html GNU/GPL
# Joomla! is Free Software
# READ THIS COMPLETELY IF YOU CHOOSE TO USE THIS FILE
# The line just below this section: 'Options +FollowSymLinks' may cause problems
# with some server configurations. It is required for use of mod_rewrite, but may already
# be set by your server administrator in a way that dissallows changing it in
# your .htaccess file. If using it causes your server to error out, comment it out (add # to
# beginning of line), reload your site in your browser and test your sef url's. If they work,
# it has been set by your server administrator and you do not need it set here.
## Can be commented out if causes errors, see notes above.
#Options +FollowSymLinks
# mod_rewrite in use
RewriteEngine On
RewriteRule ^joomla/(.*)$ /$1 [R=301,L]
########## Begin - Rewrite rules to block out some common exploits
## If you experience problems on your site block out the operations listed below
## This attempts to block the most common type of exploit `attempts` to Joomla!
# Block out any script trying to set a mosConfig value through the URL
RewriteCond %{QUERY_STRING} mosConfig_[a-zA-Z_]{1,21}(=|\%3D) [OR]
# Block out any script trying to base64_encode crap to send via URL
RewriteCond %{QUERY_STRING} base64_encode.*\(.*\) [OR]
# Block out any script that includes a <script> tag in URL
RewriteCond %{QUERY_STRING} (\<|%3C).*script.*(\>|%3E) [NC,OR]
# Block out any script trying to set a PHP GLOBALS variable via URL
RewriteCond %{QUERY_STRING} GLOBALS(=|\[|\%[0-9A-Z]{0,2}) [OR]
# Block out any script trying to modify a _REQUEST variable via URL
RewriteCond %{QUERY_STRING} _REQUEST(=|\[|\%[0-9A-Z]{0,2})
# Send all blocked request to homepage with 403 Forbidden error!
RewriteRule ^(.*)$ index.php [F,L]
########## End - Rewrite rules to block out some common exploits
# Uncomment following line if your webserver's URL
# is not directly related to physical file paths.
# Update Your Joomla! Directory (just / for root)
#RewriteBase /
########## Begin - Joomla! core SEF Section
RewriteCond %{REQUEST_FILENAME} !-f
RewriteCond %{REQUEST_FILENAME} !-d
RewriteCond %{REQUEST_URI} !^/index.php
RewriteCond %{REQUEST_URI} (/|\.php|\.html|\.htm|\.feed|\.pdf|\.raw|/[^.]*)$ [NC]
RewriteRule (.*) index.php
RewriteRule .* - [E=HTTP_AUTHORIZATION:%{HTTP:Authorization},L]
########## End - Joomla! core SEF Section
15 years 9 months ago #86130 by DemoneBianco
I solved just by turning off the ARTS. You can not touch the legacy. Thansk
Time to create page: 0.154 seconds
