Kunena 7.0.2 Released
The Kunena team has announce the arrival of Kunena 7.0.2 [K 7.0.2] in stable which is now available for download as a native Joomla extension for J! 5.3.x/5.4.x/6.0.x. This version addresses most of the issues that were discovered in K 6.2 / K 6.3 / K 6.4 and issues discovered during the last development stages of K 7.0
Question Error K1.6.3 for J1.5.22
15 years 1 month ago - 15 years 1 month ago #84876 by mike2m
Replied by mike2m on topic Re: Error K1.6.3 for J1.5.22
sozzled wrote: Do you see any difference between your .htaccess file and the file htaccess.txt in your root folder?
Ha-ha-ha I have two, one for sh404sef (htaccess.txt), and another for the Core SEF (.htaccess). On this host there are multiple virtual servers on which under these conditions There is a forum Kunena 1.6.2 without any problems, but a new forum Kunena 1.6.3 does not work.
Last edit: 15 years 1 month ago by mike2m.
15 years 1 month ago #84879 by sozzled
My advice to you is to read Search Engine Optimisation (SEO in the Wiki and pay special attention to the part that reads
Joomla includes a template for this file, which is located in the root directory of your Joomla website; the file is named "htaccess.txt"; If you are experiencing problems in getting SEF URLs to operate, you should rename the file as .htaccess (do not forget the leading "." character).
I like to keep things simple. That's why I leave things like .htaccess issues to the experts. For the rest of us ordinary folk ... use the standard Joomla stuff and leave these things alone unless you really know what you are doing.
I think that you will probably fix your problems if you follow that guide. Good luck. :)
15 years 1 month ago #84881 by mike2m
I do not understand the problem persists or if you think that this is not a problem
15 years 1 month ago #84882 by sozzled
Throughout the whole of this discussion, because we have not been able to access your website, we have been speculating about the cause of your problem. If we are wrong then it's only because we have "flying blind" as it were.
Matias wrote
Something in your installation prevents you from seeing that page -- and it isn't Kunena.
I agree. I do not think this is a Kunena problem. I think this is a Joomla problem but I'm only guessing.
I think the problem lies in your .htaccess file - I could be wrong. My advice to you is to upload, from the Joomla 1.5.22 installation kit, the file htaccess.txt and place it in your site root folder. Please rename this file to .htaccess and I think this will solve your problem ... but I could be wrong.
I hope this clarifies our position for you and hope it helps.
15 years 1 month ago #84884 by mike2m
already done as you wrote, to replace the file htaccess, removed and reinstall the forum the same error 403!
15 years 1 month ago #84886 by mike2m
mike2m wrote: already done as you wrote, to replace the file htaccess, removed and reinstall the forum the same error 403!
Hurrah! problem in the router, changed the link and it worked. Topic can be closed!
Time to create page: 0.318 seconds
