Question Having a postbit problem...
15 years 9 months ago #83473 by sozzled
The problem that you are having is because of the way that you have complicated things with Joomla banners. Is there some reason that you cannot use K 1.6.2?
You wrote that you are using K 1.5 (we can see that from the website) but can you tell us what specific version of Kunena are you using?
The following user(s) said Thank You: DOPE
15 years 9 months ago #83477 by DOPE
sozzled wrote: The problem that you are having is because of the way that you have complicated things with Joomla banners. Is there some reason that you cannot use K 1.6.2?
I am using: Kunena1.5.14
When I tried to install the newest version of your product, it told me there was a version problem.
15 years 9 months ago - 15 years 9 months ago #83478 by DOPE
Ok So I have successfully installed the latest version of Kunena.
After I did the upgrade, it worked.
Now look at my forum page, it shows the toolbar at the top, and it shows up way below it as well.
emceespotlight.com/index.php?option=com_kunena&func=&Itemid=93
Do you think its that side column? Is there a way to take away that code while on the forum menu button?
Last edit: 15 years 9 months ago by DOPE.
15 years 9 months ago #83482 by sozzled
Your site template HTML has two component displays. You need to remove one of them (or use a different site template - for example, you won't have this problem with rhuk_milkyway template) or you need to discuss this issue with the people who designed your site template.
