Idea memory setting
15 years 9 months ago #82936 by winstart
memory setting was created by winstart
changed the setting to 32M in the index file by entering the code:ini_set('memory_limit','48M');
the forum works now, but i cant work on the users because of to short memory
what to do, who to tell
15 years 9 months ago #82937 by fxstein
Replied by fxstein on topic Re: memory setting
You must have WAY too much installed that is eating up your memory. Kunena will run in under 10MB together with JomSocial integration activated. On a perfectly tuned server, it can run in under 5MB.
I would assume that you are running something else that is consuming a ton of memory. If you have 3rd party SEF, turn it off, also try turning off other plugins and modules.
Best tu turn on Joomla debug mode and records the memory usage on any Kunena page.
As we have no way of telling what is installed on your server and in Joomla, I recommend to turn off anything that is not coming with Joomla - at least for testing - so you can find the root cause of the memory consumption.
Hope this helps!
15 years 9 months ago #82939 by winstart
Replied by winstart on topic Re: memory setting
doesn't look too much does it?
Profielinformatie
Application afterLoad: 0.003 seconds, 0.37 MB
Application afterInitialise: 0.078 seconds, 4.72 MB
Application afterRoute: 0.078 seconds, 4.72 MB
Application afterDispatch: 0.256 seconds, 8.24 MB
Application afterRender: 0.321 seconds, 8.99 MB
Geheugengebruik
9465820
but when i want to work on my users i get
Fatal error: Allowed memory size of 16777216 bytes exhausted (tried to allocate 60 bytes) in /home/winstart.nl/public_html/HJ/libraries/joomla/language/language.php on line 353
15 years 9 months ago #82941 by winstart
changed to native mode
now i get this when i want to work with the usersettings
Profielinformatie
Application afterInitialise: 0.053 seconds, 3.21 MB
Application afterRoute: 0.053 seconds, 3.21 MB
Application afterDispatch: 0.249 seconds, 14.67 MB
Application afterRender: 0.314 seconds, 15.43 MB
Geheugengebruik
16228512
Fatal error: Allowed memory size of 16777216 bytes exhausted (tried to allocate 77824 bytes) in /home/winstart.nl/public_html/HJ/libraries/geshi/geshi.php on line 2106
15 years 9 months ago #82942 by winstart
and another thing, changed in my index.php the memory settings to 32M
but looking in joomla the memory still is on 16....
15 years 9 months ago #82945 by fxstein
Ok - so your runtime setting is not being accepted. 16MB can get too little depending on other plugins you have.
At first look I thought you had set it to 48MB (see code fragment of first post).
You will have to check with your hosting provider to raise the limit from 16MB to 32MB.
Not sure I understand the difference between the first and second debug list. What do you mean by native mode?
You should also provide a config report from the Kunena backend. That shows us a lot more details about your setup.
Hope this helps!
