Question Paragraph breaks not working
15 years 10 months ago #81418 by johnmasterlee
I just made a new post to a site I'm working on.
174.133.191.19/~thekarte/forum/152805-si...fixes.html#478720083
All the paragraph breaks seem to have gone missing and as a result, the text just becomes one big box.
Not sure what happened, but I do believe it was working before.
Initially, I noticed that the BBCODE toolbar was missing. I fixed that by going back to activate the SYSTEM MOTOOLS UPGRADE plug-in. Perhaps another extensions turned it off. The toolbar now works.
But the paragraph breaks still aren't which is confusing me.
Any ideas on where I might look?
I'm on the versions 1.6.2 of Kunena. Just also changed back to the default forum template too.
15 years 10 months ago #81427 by xillibit
If you paragraph like in Joomla! editor, this doesn't work under Kunena
15 years 10 months ago #81479 by sozzled
Yes, this really does not look as though it has anything to do with Kunena. This looks like it might be a copy-and-paste problem ... or possibly a defective keyboard? :unsure:
There are many examples of messages on your forum where paragraphs are properly formatted: 174.133.191.19/~thekarte/forum/141925-al...esharing-thread.html (the very first post is just one example).
15 years 10 months ago #81483 by johnmasterlee
Actually, that's the problem...
It was working before. A lot of the content you see was due to a content migration. But in the past few weeks, I was able to format paragraphs properly. You simply hit the ENTER key and a paragraph break is entered.
What's interesting is that while in EDIT mode, I can see the paragraph breaks. It's only ONCE it is displayed to the public that the formatting is completely lost.
I should note that other BBCODE is working, ie. bold.
No one else is running into the same issue?
15 years 10 months ago - 15 years 10 months ago #81487 by sozzled
Can we try this for ourselves, please? I am really wondering if the problem is not a defect with your keyboard.
Obvious question: before what?
Can you provide us with a test account? Thanks.
Last edit: 15 years 10 months ago by sozzled.
15 years 10 months ago #81490 by johnmasterlee
Yes, it happens on more than one keyboard! I tried on two computers.
Use this test account:
U: mrtester
P: mrtester09
