Question Paragraph breaks not working
- johnmasterlee
174.133.191.19/~thekarte/forum/152805-si...fixes.html#478720083
All the paragraph breaks seem to have gone missing and as a result, the text just becomes one big box.
Not sure what happened, but I do believe it was working before.
Initially, I noticed that the BBCODE toolbar was missing. I fixed that by going back to activate the SYSTEM MOTOOLS UPGRADE plug-in. Perhaps another extensions turned it off. The toolbar now works.
But the paragraph breaks still aren't which is confusing me.
Any ideas on where I might look?
I'm on the versions 1.6.2 of Kunena. Just also changed back to the default forum template too.
If you paragraph like in Joomla! editor, this doesn't work under Kunena
There are many examples of messages on your forum where paragraphs are properly formatted: 174.133.191.19/~thekarte/forum/141925-al...esharing-thread.html (the very first post is just one example).
- johnmasterlee
It was working before. A lot of the content you see was due to a content migration. But in the past few weeks, I was able to format paragraphs properly. You simply hit the ENTER key and a paragraph break is entered.
What's interesting is that while in EDIT mode, I can see the paragraph breaks. It's only ONCE it is displayed to the public that the formatting is completely lost.
I should note that other BBCODE is working, ie. bold.
No one else is running into the same issue?
johnmasterlee wrote:
Obvious question: before what?It was working before.
Can you provide us with a test account? Thanks.
- johnmasterlee
Use this test account:
U: mrtester
P: mrtester09
