Question "attachment not found"
15 years 10 months ago - 15 years 10 months ago #81088 by cbrace
Hi all,
For some reason, attachments are broken on the v1.6.2 forum I manage.
Using the file picker, I can add an attachment in the message editor.
If I insert the attachment, the tags appear in the editor window, but when the message is saved, an error message is displayed:
Attachment C:\fakepath\byte-offerte-20110112.pdf not found
I looked around the configuration settings but didn't find anything, like a pathname field, that looked promising. This was working for us last fall.
Any ideas?
Thanks,
Colin
htaccess: Exists | PHP environment: Max execution time: 30 seconds | Max execution memory: 160M | Max file upload: 170M
Joomla default template details : Sense | author: K2B-media | version: 1.0.2 | creationdate: 07/20/10
Kunena default template details : Sense-Online | author: MJH | version: 1.0 | creationdate: 27-12-2010
Kunena version detailled: Installed version: 1.6.2 | Build: 3894 | Version name: Team | Kunena detailled configuration:
Last edit: 15 years 10 months ago by cbrace.
15 years 10 months ago #81331 by xillibit
Replied by xillibit on topic Re: "attachment not found"
what browser do you using ? Do you have tried with an another one ?
15 years 10 months ago #81380 by sozzled
Replied by sozzled on topic Re: "attachment not found"
cbrace: I'm sorry but I do not have any guest access to your forum (and so I cannot see the issue). My immediate advice, at this time, is to search the forum for:
(a) "attachment not found" ; and
(b) fakepath
in the hope that some of these topics might be helpful to you.
The following user(s) said Thank You: cbrace
15 years 10 months ago #81388 by cbrace
Replied by cbrace on topic Re: "attachment not found"
Sozzled,
I just discovered the cause: it was a permissions problem with this directory: /media/kunena/attachments
Changing it from 755 to 775 fixed things.
There seems to be recurring issues with permissions on the server which I host my Joomla site on; I am switching webhosting companies next week and I hope this problem will be solved for good.
The lesson seems to be: not all so-called Joomla webhosting companies are equal.
-Colin
15 years 10 months ago #81390 by sozzled
cbrace wrote: The lesson seems to be: not all so-called Joomla webhosting companies are equal.
I agree. Good point. :)
15 years 10 months ago - 15 years 10 months ago #81927 by cbrace
Hi again Sozzled,
Just a quick follow-up: I am testing my Joomla site on a new host. I made a backup with Akeeba and installed it on the new server.
Everything went fine except I did again have to manually modify the permissions for /media/kunena. Are the default settings in Kunena too restrictive? Once I added write permission to group and other, attachments worked again. I find this odd, since the webserver reads and writes as owner of the files. Why would the Kunena need group or other write permission to write files?
I notice for example that another Joomla extension I use, the excellent, DOCman, manages to write files in its document directory with the default settings, -rw-r--r--
Thanks.
Last edit: 15 years 10 months ago by cbrace. Reason: pressed enter by mistake
