This is for users to help other users, to discuss topics that are related to forum administration in general or problems in running Joomla. This is not the place to ask for Joomla support. If you want assistance with Joomla please ask at
forum.joomla.org
i know its problem with template becoz useing mootools 1.2 my ques is any idea how kind of template can i use for joomla 1.5 and also k1.6 that work with mootools 1.2. its a simple problem of submenu dropdown. if anyone have any idea or template link pls share. thank you
sozzled wrote: Let me make sure I understand your question. You are looking for a Joomla site template that is compatible with Mootools 1.2.4, is that correct?
Let me absolutely clear about your question. You would like some advice about a Joomla site template. You're looking for a template that works with Joomla 1.5.22 and that doesn't cause any conflicts with Mootools 1.2.4. Right?
If you find a template that is compatible with Mootools 1.2.4 then you should not have problems with K 1.6.1 ... but ... if you are using other Joomla extensions that are incompatible with Mootools 1.2.4 then you are likely to have problems with K 1.6.1 and you are unlikely to have problems with the Joomla site template, also.
