Question moobot_global_vars issue after upgrade from fireboard to Kunena
15 years 7 months ago #66178 by rajeshatbuzz
Today I upgraded my forum from FireBoard to Kunene latest. but I am getting some error in all the post..
Anybody help me out on this?
Bugs can be found in links below-
www.bangaloreorbit.com/index.php?option=...t&catid=4&Itemid=468
cmsGalaxy
Website Developement | Design | SEO | PPC
www.cmsGalaxy.com
15 years 7 months ago #66181 by rajeshatbuzz
I solved the issues by disabling "mooBot for mooTools Effects" plugins...
But i need mooBot for mooTools Effects plugins...Can this be fixed with mooBot for mooTools Effects enable?
cmsGalaxy
www.cmsGalaxy.com
15 years 7 months ago #66194 by fxstein
Please provide you config report (see Kunena backend)
And please attach a copy of the errors you are getting. We need to see what they are saying in order to be able and help you.
Thx!
15 years 7 months ago #66207 by sozzled
rajeshatbuzz wrote: But i need mooBot for mooTools Effects plugins...Can this be fixed with mooBot for mooTools Effects enable?
I'm sure that you need this feature but you don't need it for Kunena.
It sounds to me that these "mooBot for mooTools effects" plugins are some third-party non-standard Javascript library that are needs for some other extension you are running. The site that used to support this product (pillwax.com) does not appear to be in business any more. The entry about this software was removed from the Joomla Extensions Directory . It's also probable that the benefits of using this feature have been implemented by another, later extension ... one that is compatible with Joomla 1.5 and Mootools 1.2.4.
Seeing that you were running Fireboard, you would also have been running J! 1.5.x in legacy mode. Please read the very important information about Legacy mode .
Time to create page: 0.266 seconds
