Question Problem with site. I NEED HELP BADLY.
16 years 4 months ago - 16 years 4 months ago #54005 by stompdrive
my forums editor had problems, it would not insert bbcode into the editor area. and the img upload would not work. now i tried to install another version including files within the template directory. forum.css and smile.class.php. I only replaced these 2 files. Now When legacy is turned off on joomla, which is what i usually have it as, the error comes up Direct acces to this location is not allowed. But hwne legacy is on i get a page wit han unstyled nav bar and a bunch of errors. you can see here.
But when i turn the forum to OFF. it shows the forum and site just fine.
I think its an permissions problem or some fiels are not right. if anyone could help i would greatly appreciate it.
Please help me. i replaced the entire template directory and i am still getting these erros. PLEASE HELP I AM IN NEED to get this off the ground again.
Last edit: 16 years 4 months ago by stompdrive.
16 years 4 months ago #54006 by @quila
"Direct acces to this location is not allowed"
To solve this error check in the langauge file if you have this
defined( '_JEXEC' ) or defined ('_VALID_MOS') or die('Restricted access');
about line 23, if this line is different this error come out with Legacy turned off.
For other error, you have smile.class.php file in default_ex template folder and should not be there. Delete this file and see what happens.
Regards
16 years 4 months ago #54007 by xillibit
What kunena version do you using ? What kunena template do you using ?
16 years 4 months ago #54009 by stompdrive
1.5.12 and default_ex i believe
16 years 4 months ago #54010 by stompdrive
awesome thanks @quila it worked wow simple but bothered the heck outta me hah thansk so much life saver :)
16 years 4 months ago #54012 by stompdrive
@quila wrote: Hi,
Regards
Would u happen to be able to help me on another issue. the editor in the forum is what i was trying to fix. the editor is no responsive. it wont insert the codes, and the im upload wont insert the img. so pretty ntohing works if you want i can creat a test account for you and u can test it out. and if u possibly have files for the editor without bugs and how to install it
