Question Problem with site. I NEED HELP BADLY.
- stompdrive
But when i turn the forum to OFF. it shows the forum and site just fine.
I think its an permissions problem or some fiels are not right. if anyone could help i would greatly appreciate it.
Please help me. i replaced the entire template directory and i am still getting these erros. PLEASE HELP I AM IN NEED to get this off the ground again.
"Direct acces to this location is not allowed"
To solve this error check in the langauge file if you have this
about line 23, if this line is different this error come out with Legacy turned off.defined( '_JEXEC' ) or defined ('_VALID_MOS') or die('Restricted access');
For other error, you have smile.class.php file in default_ex template folder and should not be there. Delete this file and see what happens.
Regards
What kunena version do you using ? What kunena template do you using ?
- stompdrive
- stompdrive
- stompdrive
@quila wrote: Hi,
To solve this error check in the langauge file if you have thisabout line 23, if this line is different this error come out with Legacy turned off.defined( '_JEXEC' ) or defined ('_VALID_MOS') or die('Restricted access');
Regards
Would u happen to be able to help me on another issue. the editor in the forum is what i was trying to fix. the editor is no responsive. it wont insert the codes, and the im upload wont insert the img. so pretty ntohing works if you want i can creat a test account for you and u can test it out. and if u possibly have files for the editor without bugs and how to install it
