Question Kunena Display Forum Scout's / Bot's
  • C0n
  • C0n's Avatar Topic Author
  • Offline
  • Premium Member
  • Premium Member
  • Only the strongest will survive
16 years 4 months ago #48729 by C0n
For example you get a bot browsing your forum like yahoo or google or another search engine there indexing your url's is there a way you can display them in the online user's bar :D ?
:silly:
16 years 4 months ago #48740 by sozzled
They probably show as "guests", if they appear at all. :blink: I have no idea. If you want to do real-time analysis of who is visiting your website then install and engage a real-time website analysis tool. Kunena is a discussion forum.
  • C0n
  • Offline
  • Premium Member
  • Premium Member
16 years 4 months ago #48748 by C0n
ah ok thanks i should of known that they would proborly apear as guest's also im sorry for posting in the wrong forum again.
but thanks sozzled for the help do you know any good ones compatible with kunena that you can recommend :)
16 years 4 months ago - 16 years 4 months ago #48756 by ChaosHead
Try this: www.joomlastats.org/
P.S. With this component SEF Kunena should be disabled.
Last edit: 16 years 4 months ago by ChaosHead.
  • C0n
  • Offline
  • Premium Member
  • Premium Member
16 years 4 months ago - 16 years 4 months ago #48758 by C0n
id rather not display bots than stop seo on my forum
Last edit: 16 years 4 months ago by C0n.
16 years 4 months ago #48763 by ChaosHead
Bots you will see even if do not disable. Will not see only the detailed statistics of visiting on a forum.
Read the description under this link: www.joomlastats.org/index.php?option=com...view&id=33&Itemid=38
Time to create page: 0.312 seconds
