Sticky How to protect my forum from spam
- Jiminimonka
- Elite Member
- YBAS!
Edit administrator/components/com_kuenena/libraries/bbcode/editor.xml
I commented out the button for editor_code at approximately line 65, this will eliminate the editor toggle which allows direct html coding to be inserted.
Then I commented out the lines at approximately 87 to 107 to eliminate the buttons for image links, url links, ebay links, video links and map links.
Unfornately you need to make a note to remind you that when you upgrade the component these will be overlaid and you will need to re-apply the fixes.
Would be nice to have a parameter to allo/dis-allow these items.
- Jiminimonka
- Elite Member
- YBAS!
Spam Bot Check
ECC+
I'am using KUNENA 2.0.2
On my forum everyday I get a lot of spam generated by guest.
In settings of kunena I have sets forum for all and captcha for guest
but this is not enought.
How do you fight with this ?
**** Moderator Moved to Relevant Topic ****
** Use the Search Feature Before Posting **
- Jiminimonka
- Elite Member
- YBAS!
my kunena forum is attacked with spam!
I choose the reCaptcha and EasyCalcCheck PLUS the installation was ok but i got again spam from spam bots as guests.
I want that guests can write in my forum , so i need a good protection. Which works really.
Can you help me?
