- Thank you received: 1
Solved Issue when creating offcanvas menu for Cassiopeia
www.dr-menzel-it.de/blog/offcanvas-menue-fuer-cassiopeia
and I think I downloaded the templat e you are using
and tested it in Joomla 5.3.0 and the kunena menu still keeps the white color.
or did you give the kunena menu a different position via module?
can you place a kunena Report Configuration here?
With kind regards
Leen
- Thank you received: 195
I am using Joomla 5.2.5. I think the problem is that you have not created an offcanvas menu for Cassiopeia. Cassiopeia is a default Joomla template, I am not using the template you downloaded.Which joomla version are you using?
Thanks for the tip with the id. Adding the id to the CSS offcanvas menu was enough.Kunena has it's own offcanvas menu with id offcanvasKunena. So you better change css for Kunena's offcanvasmenu.
