Solved Login Problems
6 years 2 months ago #213996 by bynzo
Login Problems was created by bynzo
Hello everyone,
I'm new to the forum, this has happened to me for a few days:
If I enter the forum as a guest everything works regularly, if I try to access the login or password or user recovery in the user management it returns me to the homepage (Scan Page) and does not allow me to go on.
The only way to unblock the situation is to delete the user from the joomla visitors menu.
Anyone help me solve?
Thank you so much
htaccess: Exists | PHP environment: Max execution time: 120 seconds | Max execution memory: 256M | Max file upload: 25M
Joomla default template details : yoo_micasa | author: YOOtheme | version: 1.0.1 | creationdate: November 2013
Kunena default template details : Blue Eagle5 | author: Kunena Team | version: 1.5.3 | creationdate: 2020-03-31
Kunena template params:
Kunena version detailed: Kunena 5.1.19 | 2020-08-15 [ Tethys ]
Third-party components: CommunityBuilder 1.9
Plugins: None
6 years 2 months ago - 6 years 2 months ago #214011 by rich
Replied by rich on topic Login Problems
Last edit: 6 years 2 months ago by rich. Reason: Link corrected
6 years 2 months ago #214013 by bynzo
Replied by bynzo on topic Login Problems
Hi thanks for your concern, but I looked at the link you sent me, but it gives me a 404 error
6 years 2 months ago #214014 by rich
6 years 2 months ago #214016 by bynzo
Thanks again for the advice, but unfortunately I could not solve it, also because in my opinion it is not about a menu module, but it depends on the Kunena forum package.
Other tips?
6 years 2 months ago - 6 years 2 months ago #214021 by rich
== Topic moved to general Joomla (it has nothing to do with Kunena) ==
Kunena does not have a login or register form, so there is no option for password recovery. If you use the Kunena login, you get only a redirect to the Joomla registration or login. The login takes place by Joomla.
Example:
If you click on "Crea un account" you see in your browser address
webpageaddress/component/users/?view=registration&Itemid=101
But the itemid 101 is the menu item for home, therefore you will come to the home page if the login form is not found.
This problem does not always occur, but it can occur and a menu item Login Form (see image) should solve this problem.
I am sorry, but I do not know of any other attempt at a solution, even if you have a different opinion.
Time to create page: 0.177 seconds
