Question problem with easysocial plugin url / pagination
8 years 9 months ago #198348 by xreliable
When a post/reply is made in the EasySocial stream this is displayed with a "View Reply" and "View Thread"
When a user wants to click through to the Reply, the URL for "View Reply" is being formatted as:
site.com/forum/category/12531-best-wiget/12567.html#12567
The "12567" before the ".html" and appended to the end represent the "Real Post ID" (kunena administrator language)
This will actually take the user to that reply BUT this causes problems with the pagination. If for example you have a forum with 10 posts per page and say you click on page 3 of the pagination the URL would be:
site.com/forum/category/12531-best-wiget/12567.html#12567?start=20
However that URL is based upon this improperly formatted version that was created via the EasySocial stream, and won't actually take you to page two of the pagination. From the actual kunena navigation should be:
site.com/forum/category/12531-best-wiget?start=20
This is on Kunena 5.0.13 using Blue Eagle5, Joomla 3.8.5, php 7.0.27
8 years 7 months ago #198919 by xreliable
using 5.1 RC4 "seems" to have resolved the pagination issue but I really can't test it properly. The reason that I say this is because I can run Kunena but with the EasySocial plugin enabled, the rest of the site is returning 404 errors with "Call to undefined method KunenaForumTopic::authorise()"
So I can't test the EasySocial stream to confirm this is 100% fixed.
I'd hate to have to uninstall 5.1 RC4 since I've just traded one problem for another but this later problem is pretty major.
So it seems that this plugin needs to be updated for 5.1. Will that be coming any time soon?
8 years 7 months ago #198952 by xreliable
Worked with Stackideas and one of their programmers provided a fix to two files for their Kunena app. This has resolved the stream and pagination issues. Do you want copies of the files they provided updates for?
8 years 7 months ago #198957 by 810
ok thnx, please add the plugin, or send to [email protected] then i will merge the changes on our plugin to.
8 years 7 months ago #198959 by xreliable
here are the two files which reside at:
../media/com_easysocial/apps/user/kunena/kunena.php
.../media/com_easysocial/apps/user/kunena/themes/default/streams/reply.preview.php
8 years 7 months ago #198961 by 810
ok, that plugin we don't support. That's their other plugin. I think they will add the fix on the next release.
