Question EasySocial and kunena points integration
8 years 9 months ago #198289 by xreliable
The EasySocial plugin works pretty well but a few things should happen with the EasySocial points system
1) Display Rank in profile. If you have the EasySocial plugin activated and you display rank in profiles, the rank is not integrated with the EasySocial point system. It displays the Kunena rank system and does not reflect the user's full points. So this is confusing to users and causes a duplicate point system to run if you want to display the user rank. Rank is a good feature and worthy of proper integration. If the plugin is active then EasySocial should be the single point system and kunena actions should feed into that system and rank should be cumulative for the user based upon their EasySocial profile / points.
2) There are only three rules for Kunena and EasySocial points. It would be good to have points for every Kunena action that you want to encourage. Also each positive action should have a corresponding negative action / negative points. So for example if you get 10 points for starting a thread, you should get -10 points if your thread is deleted.
Time to create page: 0.097 seconds
