Loved SchuWeb Sitemap generator
3 years 8 months ago #227266 by svanschu
2 years 10 months ago #230034 by svanschu
Replied by svanschu on topic SchuWeb Sitemap generator
SchuWeb Sitemap 5.0.0-rc2 is available with a new code base, Joomla 4+ and new XML generation options
extensions.schultschik.com/schuweb-sitem...eb-sitemap-5-0-0-rc2
2 years 9 months ago #230346 by svanschu
SchuWeb Sitemap 5.0.0 is available with a new code base, Joomla 4+ namespacing and new XML generation options
Version 5.0.0 is a b/c break in XML generation to every earlier versions. Therefore it is not an automated updated. You need to manually update the extension or set the Joomla! extension update to allow release candidates. Please read the notes.
extensions.schultschik.com/schuweb-sitem...chuweb-sitemap-5-0-0
2 years 8 months ago #230402 by svanschu
Immediate availability of the Joomla plugin SchuWeb Sitemap Integration for Kunena in version 5.0.1.
This fixes missing topics in the sitemap and incorrect URLs in the generated XML, which were introduced in version 5.0.0.
The plugin is compatible with the Joomla5 CMS and is OpenSource.
The following user(s) said Thank You: nickza
2 years 8 months ago #230479 by nickza
Replied by nickza on topic SchuWeb Sitemap generator
Thankyou for this.
I have updated, but have an issue with viewing the xml. I get a template error and think that google cannot access the sitemap.
The error is only with kunena sitemap
2 years 8 months ago #230492 by svanschu
Hi, nickza
I would need some more information. Do you have a link to show me your issue?
Did you read the documentation that the XML generation changed in the Version 5?
Time to create page: 0.292 seconds
