Question Login Location
11 years 1 month ago - 11 years 1 month ago #169582 by jthornton
Login Location was created by jthornton
We are upgrading to Kunena 4.0.6 and have a test site up here .
Where can I change the items in the right column and move them to the bottom and delete the right column? I would also like to reduce the side padding to a pixel or two.
Report Configuration.
htaccess: Missing | PHP environment: Max execution time: 30 seconds | Max execution memory: 128M | Max file upload: 2M
Joomla default template details : protostar | author: Kyle Ledbetter | version: 1.0 | creationdate: Unknown
Kunena default template details : Blue Eagle | author: Kunena Team | version: 4.0.6 | creationdate: 2015-09-28
Kunena version detailed: Kunena 4.0.6 | 2015-09-28 [ Pielungo ]
Third-party components: CommunityBuilder 2.0.11
Plugins: None
Last edit: 11 years 1 month ago by xillibit.
11 years 1 month ago #169585 by sozzled
Replied by sozzled on topic Login Location
I am not sure that I understand your question. Is the area I have hightlighted in the image below the "right column" that you want to change, move to the bottom and delete from the right?
11 years 1 month ago - 11 years 1 month ago #169594 by jthornton
Replied by jthornton on topic Login Location
Yes, that is exactly correct, I would like the content column (left) to be 100% of page width.
JT
Last edit: 11 years 1 month ago by jthornton.
11 years 1 month ago #169596 by 810
Replied by 810 on topic Login Location
Then you must go to
backend - modules
Select login form - Menu Assignment - change the dropdown to "Only on the pages selected"
Then unselect: Kunena- Forum, and on main menu -forum
Do the same for the Community - Whos Online module
11 years 1 month ago - 11 years 1 month ago #169597 by sozzled
No problems. It is simply a matter of assigning a different module position for the Login and Users Online modules. At the moment, you have assigned these to position position-7 (in the standard Joomla protostar) template.
Unfortunately there is only one postition at the bottom of the protostar template that you can use and that is the footer position. Obviously, different templates for Joomla have other module positions that may be more appropriate (you can search the internet for places where you can obtain other templates for J! 3.x).
This is not really a question about Kunena. It's more a general question about Joomla ... but I am happy to have given you a couple of ideas.
Last edit: 11 years 1 month ago by sozzled.
11 years 1 month ago #169599 by jthornton
Thanks so much.
JT
Time to create page: 0.163 seconds
