Solved Im New to Kunena and getting spam everyday. Need Help configuring.
11 years 3 months ago - 11 years 3 months ago #166783 by 810
use also the joomla recaptcha 2.0 plugin.
With both enabled you should be spam free.
Last edit: 11 years 3 months ago by 810.
11 years 3 months ago #166788 by sozzled
810 wrote: use also the joomla recaptcha 2.0 plugin
... which, by the way, does not work with 99% of K 4.0 templates (it only works with Crypsis) and it does not work with the Kunena Discuss plugin, neither of use the Joomla Captcha - reCaptcha plugin.
11 years 3 months ago #166818 by ratmil
What I meant was that R-Antispam works as two layer filter, if using Akismet. It checks spam on user registration and on message posting. If one fails, the other may still work.
11 years 3 months ago #166825 by 810
@Michael, now its working on discuss 3.1
11 years 3 months ago #166839 by sozzled
810 wrote: @Michael, now its working on discuss 3.1
What are you talking about? What is "it" that is now "working" on "discuss 3.1"? I have tested Kunena Discuss (version 3.1) on three websites all using K 4.0.3 with the Joomla Captcha - reCaptcha plugin enabled. In all cases, Kunena Discuss v 3.1 uses the Kunena component configuration settings to display the CAPTCHA.
In all cases, the CAPTCHA that is displayed is Google's reCAPTCHA version 1 not version 2 as you wrote in msg #21 earlier.
I'm confused. What has changed—between what I wrote (after testing the situation) 24 hours ago and now—to make Kunena Discuss 3.1 work differently? :S
11 years 3 months ago - 11 years 3 months ago #166841 by sozzled
I have to apologise. :blush: The numbering is what confused me. Kunena Discuss version 3.1 (not version 3.0.7 which was the version I was using)!
Because I had not seen any announcement, no indication for the sudden appearance of an unusually named version "3.1" on the scene, this was the reason for my confusion.
Last edit: 11 years 3 months ago by sozzled.
