Question Help me please!!!
12 years 5 months ago - 12 years 5 months ago #156712 by Dirk Dittrich
Hello people!
I'm new here. My english is very bad. I use the goggle translator. Sorry!
Can someone please help me. I have made yesterday made ​​an update to version 3.0.5.
Now I have received many messages.
Strict Standards: Only variables should be assigned by reference in /var/www/virtual/speditiongressel.de/htdocs/modules/mod_maximenu_CK/mod_maximenu_CK.php on line 14 Strict Standards: Non-static method modmaximenu_CKHelper::GetMenu() should not be called statically in /var/www/virtual/speditiongressel.de/htdocs/modules/mod_maximenu_CK/mod_maximenu_CK.php on line 42 Strict Standards: Only variables should be assigned by reference in /var/www/virtual/speditiongressel.de/htdocs/modules/mod_maximenu_CK/helper.php on line 52 Strict Standards: Non-static method JSite::getMenu() should not be called statically in /var/www/virtual/speditiongressel.de/htdocs/modules/mod_maximenu_CK/helper.php on line 125 Strict Standards: Non-static method JApplication::getMenu() should not be called statically in /var/www/virtual/speditiongressel.de/htdocs/includes/application.php on line 539 Strict Standards: Only variables should be assigned by reference in /var/www/virtual/speditiongressel.de/htdocs/modules/mod_maximenu_CK/helper.php on line 125 Strict Standards: Non-static method modmaximenu_CKHelper::CreateModulesList() should not be called statically in /var/www/virtual/speditiongressel.de/htdocs/modules/mod_maximenu_CK/helper.php on line 129 Strict Standards: Only variables should be assigned by reference in /var/www/virtual/speditiongressel.de/htdocs/modules/mod_maximenu_CK/helper.php on line 537 Strict Standards: Non-static method JSite::getMenu() should not be called statically in /var/www/virtual/speditiongressel.de/htdocs/components/com_phocagallery/router.php on line 38 Strict Standards: Non-static method JApplication::getMenu() should not be called statically in /var/www/virtual/speditiongressel.de/htdocs/includes/application.php on line 539 Strict Standards: Only variables should be assigned by reference in /var/www/virtual/speditiongressel.de/htdocs/components/com_phocagallery/router.php on line 38
COM_KUNENA_WARNING_DEBUG Strict Standards: Only variables should be assigned by reference in /var/www/virtual/speditiongressel.de/htdocs/components/com_uddeim/uddeimlib25.php on line 179 Strict Standards: Only variables should be assigned by reference in /var/www/virtual/speditiongressel.de/htdocs/components/com_uddeim/uddeimlib25.php on line 307 Strict Standards: Only variables should be assigned by reference in /var/www/virtual/speditiongressel.de/htdocs/components/com_uddeim/uddeimlib25.php on line 307 Strict Standards: Only variables should be assigned by reference in /var/www/virtual/speditiongressel.de/htdocs/components/com_uddeim/uddeimlib25.php on line 323 Strict Standards: Only variables should be assigned by reference in /var/www/virtual/speditiongressel.de/htdocs/components/com_uddeim/includes.db.php on line 252 Strict Standards: Only variables should be assigned by reference in /var/www/virtual/speditiongressel.de/htdocs/components/com_uddeim/includes.db.php on line 263 Strict Standards: Only variables should be assigned by reference in /var/www/virtual/speditiongressel.de/htdocs/components/com_uddeim/uddeimlib25.php on line 307 Strict Standards: Only variables should be assigned by reference in /var/www/virtual/speditiongressel.de/htdocs/components/com_uddeim/uddeimlib25.php on line 307 Strict Standards: Only variables should be assigned by reference in /var/www/virtual/speditiongressel.de/htdocs/components/com_uddeim/uddeimlib25.php on line 307 Strict Standards: Only variables should be assigned by reference in /var/www/virtual/speditiongressel.de/htdocs/components/com_uddeim/uddeimlib25.php on line 323 Strict Standards: Only variables should be assigned by reference in /var/www/virtual/speditiongressel.de/htdocs/components/com_uddeim/includes.db.php on line 252 Strict Standards: Only variables should be assigned by reference in /var/www/virtual/speditiongressel.de/htdocs/components/com_uddeim/includes.db.php on line 263
COM_KUNENA_STAT_TOTAL_USERS: 43 | COM_KUNENA_STAT_LATEST_MEMBERS: Philipp275
COM_KUNENA_STAT_USERLIST »
COM_KUNENA_STAT_MORE_ABOUT_STATS »
COM_KUNENA_STAT_TOTAL_MESSAGES: 498 | COM_KUNENA_STAT_TOTAL_SUBJECTS: 73
COM_KUNENA_STAT_TOTAL_SECTIONS: 1 | COM_KUNENA_STAT_TOTAL_CATEGORIES: 6
COM_KUNENA_STAT_TODAY_OPEN_THREAD: 0 | COM_KUNENA_STAT_YESTERDAY_OPEN_THREAD: 1
COM_KUNENA_STAT_TODAY_TOTAL_ANSWER: 0 | COM_KUNENA_STAT_YESTERDAY_TOTAL_ANSWER: 9
Can you help mitr please?
Last edit: 12 years 5 months ago by Dirk Dittrich.
The topic has been locked.
12 years 5 months ago #156715 by 810
Replied by 810 on topic Help me please!!!
you need to upgrade modmaximenu and uddeim.
The following user(s) said Thank You: Dirk Dittrich
12 years 5 months ago #156858 by Dirk Dittrich
Replied by Dirk Dittrich on topic Help me please!!!
Thanks for the reply! I had found the problem quickly and simply.
I had to turn off only the debug mode. Then everything was back to normal!
