Solved How to separate Kunena users from Joomla Users?
12 years 7 months ago #155089 by raffetali
Can anyone tell me please how to separate Kunena users from Joomla Users?
I don't want the Joomla users to be the same as Kunena users. Is that possible?
Many thanks for your help and support.
Best Regards
Raffet Ali
12 years 7 months ago #155092 by sozzled
I think you should read the background information in User registration and login issues and Can I run Kunena without Joomla and you will then understand the reasons why your request is not possible. The simple fact is that Joomla users automatically become forum users (unless you have some special ACL rules that prevent your users from using the forum).
And that's the best answer I can give you based on the information that you have given us.
I hope this helps.
12 years 7 months ago #155096 by raffetali
Thanks a lot...
