Question Tigra template errors/problems
12 years 11 months ago - 12 years 11 months ago #151412 by Byrad
I am using Kunena Forum 3.0.3
joomla 3.2
and ı am using tigra kunena template but My editor does not open :(
I have given you is like in the picture if someone please help me to solve
Last edit: 12 years 11 months ago by Jiminimonka.
12 years 11 months ago #151413 by 9themestore
Hi Byrad,
You try to switch to Kunena default template if it work you should contact with the template provider to check this issue.
Best regards,
12 years 11 months ago #151414 by Byrad
Is there no other way? :(
12 years 11 months ago #151415 by 9themestore
There is a way, you try to update latest version of JS for tigra template. Before update you should backup the current template. I wish you success.
Best regards,
