Question Forum-Navigation is missing, coming from module "last forum posts"
12 years 11 months ago #151336 by Artaxerxes
I am using Kunena 3.03 and Joomla 3.1.5.
When I click on the module "Latest forum postings", the kunena menu is always missing. No top-navigation in the forum.
Can anybody reproduce that or knows a solution?
Thanks in advance
The topic has been locked.
12 years 11 months ago #151338 by 9themestore
Hi Artaxerxes,
Try to config the Kunena menu module show all joomla! page.
The following user(s) said Thank You: Artaxerxes
12 years 11 months ago - 10 years 4 months ago #151339 by rich
Welcome to kunena, Artaxerxes!
This error occurs when kunena menu items are used in other menus. Links of other menus, which are linked to the forum, must be menu type "Menu Item Alias".
Please see here: www.kunena.org/docs/en/troubleshooting/menu-issues
If you are creating a configuration report, I can tell you which menu items are wrong.
www.kunena.org/docs/en/faq/configuration-report
Last edit: 10 years 4 months ago by rich.
12 years 11 months ago - 12 years 11 months ago #151341 by Artaxerxes
I can't find any module for Kunena navigation bar on top and I don't want Kunena to appear on all pages :)
That was the solution. Thanks!
Last edit: 12 years 11 months ago by Artaxerxes.
12 years 9 months ago - 12 years 9 months ago #153882 by bitpt
I have same problem, however, in joomla i remove mootols by default.
Hack kunena to load, in initialize.php from template.
doc =& JFactory::getDocument(); $doc->addScript("/media/system/js/mootools-core.js") ; $doc->addScript("/media/system/js/mootools-more.js") ;
But, no bbcode ---> Loading BBCode editor...
No tabs, no preview...
htaccess: Exists | PHP environment: Max execution time: 30 seconds | Max execution memory: 256M | Max file upload: 50M
Joomla default template details : Bitpt | author: Rui | version: 1.0.2 | creationdate: Unknown
Kunena default template details : Blue Eagle | author: Kunena Team | version: 3.0.4 | creationdate: 2013-12-22
Kunena version detailed: Kunena 3.0.4 | 2013-12-22 [ Ukko ]
Third-party components: UddeIM 3.3
Plugins: None
Modules: Kunena Latest 3.0.1
Last edit: 12 years 9 months ago by bitpt.
12 years 9 months ago - 12 years 9 months ago #153883 by sozzled
bitpt wrote: I have same problem ...
I think you have a very different problem; you have at least two problems. The first problem is caused by your Joomla menu - see Kunena menu issues for what you can do about that. You deleted the Kunena menu; this explains why you have no "tabs"
The second problem is that you have removed Joomla's Mootools. Please read Javascript and Kunena . No Mootools => no BBcode toolbar; no Mootools => no preview. It's as simple as that. It's up to you to decide if allowing Mootools to load properly is not as important as having a forum that works.
Last edit: 12 years 9 months ago by sozzled.
Time to create page: 0.158 seconds
