Solved Nothing happens when I click on some of the links (.htaccess file issues)
12 years 6 months ago #150655 by picht
Hi
I have a problem...
When i (administrator with admin rights) click on e.g. Lock thread og delete thread, the page reloads but nothing has happened. I can click on it 5 times and nothing happens.
If i then go to another page on the site and back to the Kunena forum, then i get the message that the thread has been deleted (and i get the message 5 times)
I have caching off on both Joomla and Kunena.
Regards
Picht
12 years 6 months ago #150670 by sozzled
picht wrote: I have a problem...
I don't know how to help you. I suggest you look at the advice posted many times around this forum (and at thte top of this page) that looks like this:
If you are using the forum to discuss your problems then, for your own benefit, it would save us all a lot of time if you would kindly post your configuration report when you ask for help. If you do not post your configuration report we will not ask you for it but you may not receive a solution to your problem, either.
12 years 6 months ago #150672 by picht
My apologies.
Her it is:
htaccess: Exists | PHP environment: Max execution time: 3000 seconds | Max execution memory: 256M | Max file upload: 100M
Joomla default template details : GossipFX | author: JoomFX.com | version: 1.0.0 | creationdate: Unknown
Kunena default template details : GossipFX | author: JoomFX | version: 2.0.4 | creationdate: 2013-02-06
Kunena version detailed: Kunena 3.0.3 | 2013-10-20 [ Bifrost ]
Third-party components: CommunityBuilder 1.9.1
Plugins: None
Modules: Kunena Latest 3.0.1
12 years 6 months ago #150679 by sozzled
You should ask the developer of the Kunena template you are using why it is not working with K 3.0.3 or if they have an updated version that works with K 3.0.3.
Also, you might try simplifying your Kunena menu - try the standard menu - to see if it helps. The FAQs page (see the menu item/tab at the top of the forum here) has information about how to use the standard Kunena menu.
12 years 6 months ago #150713 by picht
Well that was very quick to blame the template...
Actually the template works fine, same problem with the defauilt one. And the menu is the same as the default but translated to Danish. There are some other menuitems, but they are unpublished (old test ones)
I have found that the problem lies in the .htaccess file.
It looks like this:
<IfModule mod_rewrite.c> RewriteEngine On RewriteCond %{HTTP_HOST} !^www\. RewriteRule ^(.*)$ http://www.%{HTTP_HOST}/$1 [R=301,L,E=Cache-Control:no-cache] </IfModule>
It makes www. in front of the URL to avoid problems with people logging in using URL without www, and then it disables the cache.
If i remove the URL rewrite and leave it like this:
<IfModule mod_rewrite.c> RewriteEngine On RewriteRule (.*) - [L,E=Cache-Control:no-cache] </IfModule>
then everything works fine. No problems anymore.
But does anyone know why thi is so and how i combine both things and get i to work properly ?
12 years 6 months ago #150777 by Matias
I think you can make two rules out of it. First for just redirect and the second to disable the cache?
But why do you want to disable cache as Joomla does that already?
If you don't want to have redirects as permament (cached), use 303 instead.
Time to create page: 0.297 seconds
