Question PHP problems - xcache not properly configured
13 years 3 months ago - 13 years 3 months ago #147362 by IlRosso
When i try to install a new kunena template i obtain this error:
500 Internal Server Error
Fatal Error was detected!
Fatal Error: xcache_clear_cache() [ xcache.lighttpd.net/wiki/InstallAdministration ]: xcache.admin.user and/or xcache.admin.pass settings is not configured. Make sure you've modified the correct php ini file for your php used in webserver. in libraries/kunena/cache/helper.php on line 111
The error was detected in the Libraries.
There is a solution?
Last edit: 13 years 3 months ago by IlRosso.
13 years 3 months ago #147363 by xillibit
you need to configure correctly xcache : xcache.lighttpd.net/wiki/InstallAdministration
13 years 3 months ago #147364 by IlRosso
i don't understan how can i generate user and password, can you help me?
13 years 3 months ago - 13 years 3 months ago #147369 by Jiminimonka
While someone may be able to help you with this issue, it is unrelated to Kunena. It is a configuration problem with your site setup. Please contact your hosts or look into the documentation for whichever system you site is hosted on.
Kunena does not handle user registration, it is handled by Joomla.
Please read the FAQ.
Only one question per topic.
Last edit: 13 years 3 months ago by Jiminimonka.
