Question Wrong menu item cause 404 error
13 years 3 months ago - 13 years 3 months ago #147206 by joomjohn
After installing kunena, everyhting is ok until I tried to visit the link (alias menu item) created I got a 404 error, Before posting I have read :
Kunena_menu_issues
Customised_menus
Troubleshooting_Kunena_Menu
I noticed that the problem is that the itemid was wrong because when I manually change the itemid of the url, the kunena forum was displayed, the alias menu item is pointing to the id of itself ! instead of pointing to the itemid of the kunena menu here is some screen shots
the ID of Kunena menu item is 729
Menu item alias generated by Kunena is 738
in details info of the menu item alias the itemid is 729 which is correct
but when you visit the link the you get 404 error and the itemid is wrong , it's the itemid of the menu item alias it self !
for more information about menu items please check the section "Kunena menu details:" in the configuration below
Joomla! SEF: Disabled | Joomla! SEF rewrite: Disabled | FTP layer: Disabled |
htaccess: Missing | PHP environment: Max execution time: 60 seconds | Max execution memory: 128M | Max file upload: 60M
Joomla default template details : zt_genius | author: ZooTemplate.com | version: 2.5.0 | creationdate: Unknown
Kunena default template details : Blue Eagle 2.0 | author: Kunena Team | version: 3.0.1 | creationdate: 2013-06-29
Kunena version detailed: Kunena 3.0.1 | 2013-06-29 [ Noordwijkerhout ]
Plugins: None
Last edit: 13 years 3 months ago by joomjohn.
The topic has been locked.
13 years 3 months ago - 13 years 3 months ago #147222 by sozzled
G'day, joomjohn, and welcome to Kunena.
Try flushing your web browser cache. Also please see Support for PC-hosted websites (e.g. WAMP, XAMPP) .
Last edit: 13 years 3 months ago by sozzled.
The following user(s) said Thank You: joomjohn
13 years 3 months ago - 13 years 3 months ago #147232 by joomjohn
Thank you very much for your fast answer, I tried to change the browser, flush the DNS ... but the same problem, also my wamp server in well configured, the problem is I checked the database and the itemid was correct, but the only place where the itemid is wrong is the menu link from the front end, do you have any idea where the generation of the links happened, because it's a strange problem, the value of the itemid in menu link is correct but when rendered in front end the itemid is wrong !
Thank you
Edit :
is there any problem if I user the "external link" instead of "menu item alias" and put the "index.php?Itemid=750" as link, because I see it works, but the menu link is not activated, and it may influence the SEO since that I will not have a SEF link, any suggestion ? I tried to re-install kunena, restore the menu links from kunena options... I start to believe that it's a Joomla issue !?
13 years 3 months ago #147236 by sozzled
Let me be sure I understand what you are saying. Your configuration report and the screenshots taken from your Joomla administration site show a properly set up Joomla menu arrangement but, when you go to your frontend, your Joomla menu is different. Have I correctly interpreted the meaning of your question to us?
13 years 3 months ago #147239 by joomjohn
yeah, the only problem is here
the generated link in the front end
thank you :)
13 years 3 months ago #147242 by sozzled
If you read The Kunena menu in the Wiki, you will see the the Kunena menu is a Joomla menu. There is nothing particularly mysterious about it. If your Joomla menu does not work for you in the frontend, it is most probably because you are using a cached value on your server.
If you clear your server cache (there are standard Joomla features to do that), or if you are using some other caching mechanism, like APC, then you need to modify the cache settings or clear the cache in some other way (or wait until the cache clears itself).
I would bet that if I could access your website, I would probably see something different to you but, because your website is built on a webserver that is not connected to the internet, then you are on your own and you will have to figure out why your Joomla menus are not being updated in the frontend when you make changes in your administration site.
What is quite puzzling about this whole issue is that, for no obvious reason, the frontend link you described in msg #1 pointed to itemid=738. In msg #5, itemid-759.
Can you explain how this happened?
Time to create page: 0.161 seconds
