Question How to auto-add text to forum posts in a certain section
13 years 9 months ago #140767 by soutysjo
Hi
Couldn't find that anywhere on the forum. Is it possible to create a forum section, in which every post will have the same text added to it automatically?
I want to create a sensitive forum section and make sure that each user's post there will contain short T&C's.
Thanks!
13 years 9 months ago - 13 years 9 months ago #140775 by sozzled
G'day, soutysjo, and welcome to Kunena.
I'm not sure what exists to achieve a solution to the problem as you have described it. It may be possible (if you have the skill or are prepared to pay a developer to write a plugin or to customise the forum template for you) to add certain text such as a link to your site's terms of use.
In the case of this website here, you will observe that each page on the site displays a link to the site's terms of use (at the foot of each page) and maybe that would be the simplest, almost zero-cost, solution in your case.
Another option is to add the [linked] text as part of the section/category description or to incorporate the link into your signature when you reply to topics posted in that section (or categories within it).
Last edit: 13 years 9 months ago by sozzled.
13 years 9 months ago #140777 by soutysjo
Thanks for the quick reply, I'll try to find a way to sort it out.
