Solved Included javascript tooltip doesn't work with Kunena 2.X
- ChiakiAccess
So since upgrading to Kunena 2.X from 1.X darktip isn't working anymore. Darktip is a javascript generated tooltip for Blizzard games. What it does is look for hyperlinks with a certain look and attach a tooltip to them. It works fine for any page and article except for Kunena. It worked with Kunena 1.X, though.
If I look at the code I do see that the javascript files are included in the <head> of the template as they should be, but nothing happens when I put the mouse over such a hyperlink.
Something is overriding the javascript I guess but I don't know what that may be.
There were some problems with mootools in the past with that script but it has a yepnope-check or something built in since then as a workaround.
You can find the github link here: github.com/darkspotinthecorner/DarkTip
This is not a defect of K 2.0 but, I agree, it may be an issue that requires the developers of DarkTip to discuss with the Kunena development team. Perhaps you might like to ask the DarkTip developers to discuss this with the Kunena developers?
- ChiakiAccess
plus.google.com/109019720443407643481/posts
And the developers of Kunena can look up all of his code on github. I guess it would be best for Kunena developers to check this out, because they know their code, which is a lot more complicated than darktip, I guess.
Maybe I should try to include the whole code in Kunena itself again? Do you know where I can find the part with doctype and <head>?
The Kunena forum component is about 120,000 lines of PHP code and, yes, it's probably a little more complicated than DarkTip.
- ChiakiAccess
The problem was: I included the scripts without using a "/" to mark the absolute path to root. For some reason it worked for Joomla and the template itself but not within Kunena. Now by adding "/" it works! Sorry for wasting your time because of my stupidity.
Thanks for your help! It was fast and thorough.
