Question Does anyone have a fix for "Ice Vertical Menu" when used with Kunena 1.7.2?
14 years 3 months ago #118114 by Marcool
I'm just wondering if my previous post in the subject Strange interaction between Kunena "New subject" page and JS Menu is readable... It just gives me a white screen on my machine (various browsers). Is there maybe a problem with the length of the post, I maybe shouldn't have included so much code in raw format like that...
Could an administrator please look into this for me as it does seem the data from my message is there only unaccessible.
Thanks in advance,
Regards,
Mark.
14 years 3 months ago - 14 years 3 months ago #118115 by sozzled
G'day, Marcool, and welcome to Kunena.
I also could not read your earlier message and I don't know why. Perhaps it was the raw code that you posted. I assume that you cannot edit you previous message. We don't need always need a lot of detail to understand the problems. Evidently something you posted on the forum caused a problem with the software that was unanticipated. These things happen from time to time and it would seem as this particular problem (caused by something that you previously posted) will have to remain a mystery for the time being.
Perhaps you should read the posting guide printed at the top of this page and start by giving us some information about your Joomla set-up. Your configuration report will give us that information.
You should also read msg #1 of If you are having problems with Kunena, please read this first which addresses Javascript-related problems. Maybe this will help you in your case.
Last edit: 14 years 3 months ago by sozzled.
14 years 3 months ago #118116 by Marcool
Ngierk...
I hoped that wouldn't be the answer (although I figured the odds were low...) and that I wouldn't have to retype my message...
That's what I'll do anyway, maybe you could trash the broken thread for me and I'll continue in this one then!
14 years 3 months ago - 14 years 3 months ago #118117 by Marcool
So here goes...
The config report of Kunena is bellow :
htaccess: Missing | PHP environment: Max execution time: 30 seconds | Max execution memory: 100M | Max file upload: 32M
Joomla default template details : revatemplate | author: Reva | version: 1.0.0 | creationdate: Janvier 2012
Kunena default template details : Blue Eagle (default) | author: Kunena Team | version: 1.7.1 | creationdate: 2011-11-16
Third-party components: CommunityBuilder 1.7.1
And I also have a fleet of little modules and other things, the main one of concern in this case being Ice Vertical Menu published by IceTheme .
My problem arrises psecifically on the New Subject page... When on any other part of the forum, or of the site, my menu behaves correctly, presinting dynamic JS submenus onmousehover.
But on the New Subject page the menu seems to break somehow and the submenus are printed not in their correct place but aligned with the menus main div on the right...
I know that both this menu and Kunena make extensive use of the mootools library, and I'm pretty sure there must be a conflict in there somewhere.
The thing is I'm nowhere near adept enough at JS to diagnose such a problem, and I'm wondering if you could maybe help me identify where the problem is coming from.
You can obtain a copy of the menu in question here , that and Kunena should be sufficient to reproduce the error (although I have not tested on anything other than my own config).
Please beleive me when I say that I have messed with all the options I could possibly find in both the menu and Kunena, and that I can't find any logical explanation for this in user-standard configuration, nor on the internet.
Here are a few pictures showing the problem :
This is normal behavior:
[IMG
This is the problem
[IMG
Thanks in advance for your help.
Last edit: 14 years 3 months ago by Marcool.
14 years 3 months ago #118120 by sozzled
You have menu problems. If you want to build a custom menu, please read how to go about doing it: Customised menus .
I suggest that you start by getting Kunena to work "normally" before you experiment with customised menus. Read How do I restore my Kunena menu? I also think you should familiarise yourself with Search Engine Optimisation (SEO)
Ugrade to K 1.7.2 (which fixes a lot of problems).
Are you running your website on your local PC under XAMPP for example ... or have you modified your configuration report in any way?
What happens if you do not use that Ice Vertical Menu module. I can't tell you any more because I cannot access your website, but I think the answer to your problem is to read msg #1 of If you are having problems with Kunena, please read this first .
14 years 3 months ago - 14 years 3 months ago #118198 by Marcool
Hello sozzled,
Firstly, I had read the "If you are having problems with Kunena, please read this first" article before posting, as it's title, nobody can argue, is rather explicit...
On the other hand it seems my post is not explicit enough, as I do not have any problem with the kunena menu, that one is working fine, it is the other menu that breaks when on the New Subject page, not the Kunena Menu.
I have upgraded to 1.7.2 this morning to no effect.
I am indeed working on a MAMP installation to create the website, and honestly I see no reason what so ever for anybody to ever modify their configuration report... I can assure you I didn't anyway! Here it is again just in case :
I do know that this is not a problem with Kunena... I spoke extensively about that in my first post... the one that is broken, and although I was less detailed in the second post (my patience was low at that point), I am only here to ask for help and advice as to what could be breaking the Ice Vertical Menu module when the New Subject page is called, if you could tell me in any way how that page differs from others, apart from the fact that it has a load of <post> in it... that would be helpful in trying to figure out why the module is acting up.
Kunena is a fantastic forum, very customisable and to date perfectly suited to my needs. I can't help but congratulate the whole team for that! I know in my case the problem is with my relatively "old" module, and I would just like help in fixing it.
I have already posted on the forum of the menu developer and I wanted to try and get some help from people who understand Kunena better that me (or them).
Thank's again for a great forum, and for your help in this.
Regards,
Mark.
Time to create page: 0.259 seconds
