Merged Add post manually
I found some old backup from an old database with a forum for a version of my site xoops. I wanted to integrate in Kunena, but the xoops database is not complete and I can not restore the old site. Since the posts are few, I thought I put them manually.
My question is: how can I manually enter each user's post?
Thanks and sorry for my terrible english
After days of slamming into a excel file I have rebuilt an old forum (not Kunena). After cleaning and re-assigned names and ids of users of the new site I started to do some testing of import (of course backuppando like crazy).
(EDIT: I forgot! I use Joomla 2.5 and Kunena 1.7.2)
After preparing the excel file, I then proceeded to create two csv respecting the structure and _kunena_message _kunena_message_text.
I proceeded in steps, and then I began to see first how to modify the database through an existing post in a thread, so everything is ok. So I created a category and a discussion of testing (user side) and I imported a little post, so everything is ok.
But when I go to prepare a number of discussions, I have problems,
At this time I did some tests and I had a doubt .. is that the id of the discussions has some rule? Why I tried to import a discussion putting ID 300 and I see it, while the second debate in which I put ID 301 does not see it.
Or if I go to put all the threads, I see only 8 of 120 with all imessaggi staggered but it seems to me to see why more and produces 10 pages of discussion (I set 20 per page)
What do you think wrong?
As I put these fields (see image, of course, the yellow line in the csv file does not exist)
I put ID numbers from
PARENT I put the ID "above", when I put a new category 0
THREAD I put progressive number for each question
CATID because I want to enclose everything in a category when I left 12
the rest do not think it significant
thank you!
I merged your two topics (originally posted in our support category). We do not have a category for this kind of question and so I have put it here in our Miscellaneous, off-topic and general Joomla category. I hope you do not mind.
You have a unique requirement. Kunena is a lot more than just 2 database tables. While it is possible to "manually" create messages by adding records to the _kunena_message and _kunena_message_text tables, there are other tables, too. There is no support, as such, for the kind of thing that you want to do. If, however, someone from the community would like to help you directly in achieving what you want to achieve then that's a different matter.
I do not know what specific help we can give you in this job but I wish you good luck in finding a way to solve your particular problem.
Thank you for the welcome and sorry if I'm wrong category!
ok, I hope someone can help me soon.
greetings
flips
I did a test to see which tables are modified by inserting a couple of topics, are only modified rows and _message _message_text, the rest remain unchanged
