Question Error: 500 Controller CommunityPostController not found!
14 years 10 months ago #115931 by garywm
Hi all,
I am getting this error
Error: 500
Whenever someone tries to add a new post or reply to one, it happens when they sumbit the message.
Any ideas?
Gary
14 years 10 months ago #115932 by garywm
htaccess: Exists | PHP environment: Max execution time: 90 seconds | Max execution memory: 500M | Max file upload: 4M
Joomla default template details : yoo_shelf | author: YOOtheme | version: 1.0.2 | creationdate: August 2011
Kunena default template details : Argent(RC3 - stable) | author: Gonzaunit | version: 1.6.0 | creationdate: 2010-08-20
Third-party components: Jomsocial 2.4.0
Third-party SEF components: AceSEF: The file doesn't exist acesef.xml !
Modules: Kunena Latest 1.7.1
14 years 10 months ago #115962 by sozzled
Sounds like a JomSocial to me. It could be a JomSocial problem caused by AceSEF. I am not aware of a CommunityPostController function in Kunena.
Does this error also if you use the supported Blue Eagle template, instead of the unsupported template that you are using?
14 years 10 months ago #116022 by garywm
Thanks for the reply. Yes it still happens on the default template.
I am seeing people via Google that have the same error but there don't seem to be any answers :(
14 years 10 months ago - 14 years 10 months ago #116052 by sozzled
garywm wrote: Thanks for the reply. Yes it still happens on the default template.
Oh well, it was a stab in the dark.
garywm wrote: I am seeing people via Google that have the same error but there don't seem to be any answers :(
When I looked for CommunityPostController (whatever that is) on Google , I found this topic here and one (worded almost identically) that you posted to the Joomla forum and that was about the extent of it.
I don't know what this CommunityPostController is. It might be a Kunena thing but I have never heard of it before. I'll ask around.
Last edit: 14 years 10 months ago by sozzled.
14 years 9 months ago #116212 by LittleJohn
Hi
If you pm me your site details, Ill take a look.
Either if this is another component causing it or not, we need to know how we can get around this.
Regards
Time to create page: 0.146 seconds
