Question Doesn't work
14 years 11 months ago #113780 by pietrostopponi
Doesn't work was created by pietrostopponi
Hello
I have installed everything but when i click in the menu i receive a lot of error.
For example
Fatal Error: Allowed memory size of 29360128 bytes exhausted (tried to allocate 19456 bytes) in libraries/joomla/database/table/user.php on line 297
The error was detected in the Libraries.
What can I do?
Thank you
14 years 11 months ago #113782 by xpatman
Replied by xpatman on topic Re: Doesn't work
I believe this could be a server issue as I had something like this before
I was getting = Fatal error: Allowed memory size of 33554432 bytes exhausted (tried to allocate 77824 bytes) in /home/.......
My support came back with = The problem is due to lower memory limit. I have increased it to 48M now.
They did and my site works OK now
Cheers
The following user(s) said Thank You: pietrostopponi
14 years 10 months ago #114490 by Wasuup
Replied by Wasuup on topic Re: Doesn't work
I'm having exactly the same problem after upgrading to 1.7.1 - it's not due to the php.ini config as the memory allowed is loads more than the file, it's also random as to the file producing the error.
I'm hoping my host has a solution as I've tried it with a fresh install with the same error but on my local testing server it's fine.
14 years 10 months ago #114492 by 810
Replied by 810 on topic Re: Doesn't work
can you post the kunena config report here. then we can find the issue for you.
regards
810
14 years 10 months ago #114517 by Wasuup
Never mind - fixed it by increasing the php memory allowance to 64M - a bit higher than I'm used to but seems to work!
