Question Kunena Rank Issue
15 years 3 weeks ago #110193 by djmill
Kunena Rank Issue was created by djmill
Hi all, I've searched all over the internet for a solution to this problem - found 1 post, but there wasn't a solution to it so maybe you guys can help!
I've set up my forums the way I liked it, and now I wanted to add ranks in. I've changed the default ranks to custom named ranks and kept everything the same. However, when I turn on the user stats, it shows everyone listed as Administrators when they aren't.
How can I get the ranking system to actually work? The only Special rankings I have listed are Administrator, Banned, Moderator, and Spammer. It seems I can set people to the lower ranks, but I have to make them special - therefore, the ranking system doesn't increment by posts I'd have to increment the users myself = /
Help! And thanks in advance!
15 years 3 weeks ago - 15 years 3 weeks ago #110195 by sozzled
Replied by sozzled on topic Re: Kunena Rank Issue
I don't think this is a rank issue. I think that all your users are registered as administrators. It's probably a Joomla Global Configuration issue. What version of Joomla are you using?
Last edit: 15 years 3 weeks ago by sozzled.
15 years 3 weeks ago #110196 by djmill
Replied by djmill on topic Re: Kunena Rank Issue
I'm using Joomla 1.7
15 years 3 weeks ago #110198 by sozzled
You've probably given all your users administrator rights to your forum. It's pretty easy to do in J! 1.7 if you mess around with the ACL settings and you don't know what you're doing. Best idea is to set your ACL settings back to their original values. It still sounds like a Joomla issue to me.
15 years 3 weeks ago #110199 by djmill
Okay I'll give that a shot and see if it fixes things!
15 years 3 weeks ago #110200 by djmill
That was exactly it thank you very much!
