Question Point System for Kunena
15 years 2 months ago #107457 by MetroHome
Not sure if I am just looking in the wrong places, I have not found a points reward system located with in Kunena, generally used to promote activity by the other members...
It seems when not use, everyone will post to the site but will generate little comment traffic with out a point system in place.
I have the latest version of Jomsoical and Kunena, and we are presently using 1.5 for joomla.
Is there such a system in place and or do you have some advice how to over come the member activity inorder to promote more acivity..
Thanks for the time
15 years 2 months ago #107523 by xillibit
If i'am remember right Jomsocial cna do it, try to look at integration tab in Kunena configuration panel
Else you can use the component Alpha User Points to manage it
15 years 2 months ago #107536 by MetroHome
You are correct, Jomsocial has a point system, do you have any idea how to promote Jomsocial with Kunena,
For example :
1. How do you establish a point system requiring a member to have for example 10 points to make a new post.
2. How do the points display to the member so they are aware of there totals, and any other general information you may provide to get us started .
Thanks again in advance
15 years 5 days ago #111688 by MetroHome
Replied by MetroHome on topic Accumulated Post
I need a way to promote use of comments and eliminating members from just creating new threads, with perhaps the use of a points system.
What do you have for me or what alternatives are there and How do i make this application work.
