Question SOLVED: Problems with Menu assignments
15 years 3 months ago - 15 years 3 months ago #104194 by zupidupi
My Kunena-installation doesn't seem to read my Menu assignments under the module management.
My site resides at www.mattliden.fi/gym - if you press the Forum-button on the upper menu you can see that two modules, the Login-module and the one called Viktig information do not disappear. I've attached the Menu assignments for the Viktig information-module.
When the other components are selected (Calendar, Documents...) the previously mentioned modules disappear nicely, just like they should. Their Menu assignments are identical to the one connected to the Forum.
Why doesn't Kunena follow the Menu assignments?
Wonders Mike
Last edit: 15 years 3 months ago by zupidupi. Reason: Problem solved
15 years 3 months ago #104720 by zupidupi
