Important Access Problems on Kunena Forum
15 years 4 months ago - 15 years 4 months ago #101581 by Darkruler18
Hello everybody :(
I set up a website for my guild.
And i decided to work with Kunena as my favorite forum module.
The installation is okay and no errors appear.
But when i click on the "forum" link in the main menue a fatal server error appears.
I need your help :(
Best regards
Chris aka Darkruler
htaccess: Missing | PHP environment: Max execution time: 12 seconds | Max execution memory: 64M | Max file upload: 128M
Joomla default template details : jf-grafeeze | author: Alexander Seppi / Kreatif Multimedia GmbH | version: 1.6.0 | creationdate: 15 April 2011
Kunena default template details : Aphotic | author: snilloconator | version: 1.6.0 | creationdate: 2010-23-09
Plugins: System - Mootools Upgrade: Disabled | System - Mootools12: Disabled | Kunena Search 1.6.4 | My Kunena Forum Menu 1.6.4 | My Kunena Forum Posts 1.6.4
Modules: Kunena Login 1.6.4 | Kunena Search 1.6.4
Last edit: 15 years 4 months ago by Darkruler18. Reason: Added some lines
15 years 4 months ago #101587 by xillibit
I can't guess anything, so start by lookin that : docs.kunena.org/index.php/How_to_diagnose_blank_page_on_kunena
15 years 4 months ago #101659 by Darkruler18
This appears with debug mode on on mysystem :(
Has anyone an idea of what the problem is ??
Fehler
1.JDatabaseMySQL::query: 1054 - Unknown column 'parent' in 'field list' SQL=select parent, menutype, ordering from jos_menu where id = 101 limit 1
Informationen
Zurückverfolgen (Back-Trace)
Call stack
# Function Location
1 JSite->render() /users/thebrotherhood/www/Websites/joomla/index.php:49
2 JDocumentHTML->parse() /users/thebrotherhood/www/Websites/joomla/includes/application.php:250
3 JDocumentHTML->_fetchTemplate() /users/thebrotherhood/www/Websites/joomla/libraries/joomla/document/html/html.php:306
4 JDocumentHTML->_loadTemplate() /users/thebrotherhood/www/Websites/joomla/libraries/joomla/document/html/html.php:460
5 require() /users/thebrotherhood/www/Websites/joomla/libraries/joomla/document/html/html.php:405
6 include_once() /users/thebrotherhood/www/Websites/joomla/templates/jf-grafeeze/index.php:15
7 Tools->getCurrentMenuIndex() /users/thebrotherhood/www/Websites/joomla/templates/jf-grafeeze/vars.php:24
8 JDatabaseMySQLi->loadObject() /users/thebrotherhood/www/Websites/joomla/templates/jf-grafeeze/templatetools.php:103
9 JDatabaseMySQLi->query() /users/thebrotherhood/www/Websites/joomla/libraries/joomla/database/database/mysqli.php:434
10 JError::raiseError() /users/thebrotherhood/www/Websites/joomla/libraries/joomla/database/database/mysqli.php:230
11 JError::raise() /users/thebrotherhood/www/Websites/joomla/libraries/joomla/error/error.php:179
15 years 4 months ago - 15 years 4 months ago #101669 by sozzled
If you examine the error traceback, nothing indicates that Kunena is involved with this problem. Everything, on the other hand, indicates the issue arises from your J! 1.6 template menu.
Last edit: 15 years 4 months ago by sozzled.
15 years 1 month ago #109482 by jabbott
I am having the same trouble. I am using the ja_purity template and I am gettting the error:
500 - JDatabaseMySQL::query: 1054 - Unknown column 'parent' in 'field list' SQL=select parent, menutype, ordering from j17_menu where id = 21 limit 1
I don't know if it is a Kunena problem or not, but this thread is one of the only ones that google finds.
15 years 1 month ago #109485 by sozzled
jabbott wrote: I don't know if it is a Kunena problem or not, but this thread is one of the only ones that google finds.
You're right. This does not look to be a Kunena problem. You should discuss your problem with the developer of your site template. We would require more information about your website to determine the exact cause but we we could not guarantee that would would ncessarily be able to solve it for you. Try a different site template (e.g. one of the standard Joomal templates) to see if the problem goes away. If the problem goes away using a different template then you know what is the cause.
Time to create page: 0.155 seconds
