- Thank you received: 1
Question file upload slow with http and fast with https on LAN
Then i decided to switch to https and try that. An now I could upload with lightning speed.
Would could cause that?
Maybe you can try to test your internet connexion : www.kunena.com/forum/77-general-talk-abo...ion-performance-test
If running HTTPS works for you, that's good. I might give it a try myself ... one day.
I do indeed use XAMPP, but on a w2003server. I also tried to disable the firewall but that does not change anything.
If I go to \xampp\tmp i can see the file comming in, but so sloooow (approx 10kb per second). I agree it probably has nothing to do with kunena, but it shows up here so i hoped that someone else has the same problem and found a solution.
and the weird thing is that if I logon to the server with remote desktop and start my browser on the server. Uploading goes fast over http to as well the localhost and to the www.myserver.com address.
I would then say it's network related, but than https should be slow as well. Weird huh?
