Question Help with smileys
- fullstackedpoker
- Junior Member
The smileys displayed just below the editor icons are only displayed if you hit the button more smilies on the left.
It's possible to remove the smilies on the left with a bit of hacking :
in components\com_kunena\template\default\smile.class.php line 436 replace the :
with :
- fullstackedpoker
- Junior Member
Maybe it will be easier for me to just disable the top ones and use the left ones? Is that possible?
- fullstackedpoker
- Junior Member
