Question Edit time problem
16 years 9 months ago #38886 by gdsttian
Edit time problem was created by gdsttian
Is it Kunena taking the time from the server as Edit time of the post? Is it possible to set Kunena to show the time of the time zone set in Joomla!?
Thank you.
16 years 9 months ago #38898 by xillibit
Replied by xillibit on topic Re:Edit time problem
Open the file components\com_kunena\template\default_ex\message.php and replace the line 332 :
if ($fmessage->modified_by) { echo '<span class="fb_message_editMarkUp">'. _KUNENA_EDITING_LASTEDIT .': '. date(_DATETIME, $fmessage->modified_time) .' '. _KUNENA_BY .' '. CKunenaTools::whoisID($fmessage->modified_by) .'.';
with this :
$config =& JFactory::getConfig(); $tzoffset = $config->getValue('config.offset'); $ok_offsetdate = JFactory::getDate($fmessage->modified_time); $ok_offsetdate->setOffset($tzoffset); if ($fmessage->modified_by) { echo '<span class="fb_message_editMarkUp">'. _KUNENA_EDITING_LASTEDIT .': '. $ok_offsetdate->toFormat() .' '. _KUNENA_BY .' '. CKunenaTools::whoisID($fmessage->modified_by) .'.';
16 years 9 months ago #38905 by gdsttian
Replied by gdsttian on topic Re:Edit time problem
Thank you so much.
