Question Move search box right of "welcome guest"
16 years 9 months ago #37786 by kade119
it was a copy of the default_ex
the only one i received within my install
16 years 9 months ago - 16 years 9 months ago #37837 by sozzled
*** off-topic ***
I can confirm that the latest version (K 1.5.9) which I'm using in test, has four templates. These are
default_ex
default_gray
default_green
default_red
What's more, I was using K 1.5.7, I deleted everything - all the files and the directories - default_gray, default_green and default_red and then I installed the new version. Those old templates were copied back as part of the installation procedure. Therefore I don't understand the what kade119 wrote (which I quoted above).
Unless you have deleted these directories yourself, if you go to Kunena Configuration » Frontend » Template you will see a pull-down list of templates.
Last edit: 16 years 9 months ago by sozzled.
16 years 9 months ago #38175 by kade119
this is getting off topic, please refer to my original question
i'm using default_ex template...
16 years 9 months ago #38356 by kade119
16 years 9 months ago - 16 years 9 months ago #38363 by sozzled
I'm sorry, I was distracted by several other discussions that dealt similarly with whether there was only one or whether there were several templates installed (see There is only one endorsed and supported Kunena template ... default_ex which took many hours of work to establish what the facts were).
I was mainly trying to establish the facts, to make sure that you were familiar with Read this if you are template designer before, perhaps, someone might be in a good position to suggest the clues to you.
These two pieces of information are vital to the question and they are most definitely on-topic, I assure you. In fact, I have noticed a considerable falling-off in interest by the regular, experienced template designers who are either waiting for, or putting their efforts into, the next major release of Kunena. In short, any changes you make now may only be useful for the next few weeks. ?This may explain why you have not received much interest in your idea.
Returning to your original question, you will need to modify two files:
../components/com_kunena/templates/default/fb_layout.php (remove, or comment out, the code that generates the search box); and
../components/com_kunena/templates/default/plugins/profilebox/profilebox.php (insert the code that you took from the above file).
