Question Sort of Anti-spam - preventing posts with banned word
16 years 2 weeks ago - 16 years 2 weeks ago #70197 by nnggrr
Hi.
I'm trying to prevent posts uploading if the post contain sort of words.
When I looked the HTML source code of sending new post's page, I found this JavaScript lines:
function submitForm() {
submitme=1;
formname=document.postform.fb_authorname.value;
if ((formname.length<1)) {
alert("You've forgot enter the name.");
submitme=0;
formmail=document.postform.email.value;
if ((formmail.length<1)) {
alert("You've forgot enter mail address.");
submitme=0;
formsubject=document.postform.subject.value;
if ((formsubject.length<1)) {
alert("You've forgot enter the subject.");
submitme=0;
if (submitme>0) {
// var message = document.postform.message.value;
// message = message.replace(/</g,"&lt;");
// message = message.replace(/>/g,"&gt;");
// document.postform.message.value = message;
//change the following line to true to submit form
return true;
}else{
return false;
Like the conditions above, I want to add this condition:
myRegExp = /Alex/;
matchPos1 = formmail.search(myRegExp);
if (matchPos1 == -1) {
alert("we don't want any Alex.");
submitme=0;
But I didn't find the exact page which contains the code lines above.
So please:
Can you help me find the location of the code lines above?
And do you think It will do the job...
Last edit: 16 years 2 weeks ago by nnggrr.
16 years 2 weeks ago - 16 years 2 weeks ago #70328 by nnggrr
I've found where this lines are located: in folder "lib", file name: ‏‏"kunena.bbcode.js.php"
but because it is PHP file the source code is:
function submitForm() { submitme=1; formname=document.postform.fb_authorname.value; if ((formname.length<1)) { alert("<?php @print( _POST_FORGOT_NAME_ALERT); ?>"); submitme=0; } <?php if ($fbConfig->askemail) { ?> formmail=document.postform.email.value; if ((formmail.length<1)) { alert("<?php @print( _POST_FORGOT_EMAIL_ALERT); ?>"); submitme=0; } <?php } ?> formsubject=document.postform.subject.value; if ((formsubject.length<1)) { alert("<?php @print( _POST_FORGOT_SUBJECT_ALERT); ?>"); submitme=0; } if (submitme>0) { // var message = document.postform.message.value; // message = message.replace(/</g,"&lt;"); // message = message.replace(/>/g,"&gt;"); // document.postform.message.value = message; //change the following line to true to submit form return true; }else{ return false; } }
Can you please help me get this JS code lines into the PHP code above? :
var NGRegExp = /Alex/; if (NGRegExp.test(document.postform.message.value) = true) { alert("<?php @print( _POST_FORGOT_SUBJECT_ALERT); ?>"); submitme=0; }
Thanks!
  • C0n
  • C0n's Avatar
  • Offline
  • Premium Member
  • Premium Member
  • Only the strongest will survive
16 years 2 weeks ago #70349 by C0n
Do you have the locations of the files your trying to edit for example /components/com_kunena/lib/kunena.bbcode.js.php
16 years 2 weeks ago #70383 by nnggrr
C0n wrote: Do you have the locations of the files your trying to edit for example
yes. this is the exact location.
do you know how to put the JS code into this PHP page?
  • C0n
  • C0n's Avatar
  • Offline
  • Premium Member
  • Premium Member
16 years 2 weeks ago #70462 by C0n
Im assuming your using a defualt template so it would be in either "components/com_kunena/template/defualt/plugin" or it would be in "components/com_kunena/template/defualt/js"
