Kunena 6.4.13 Released
Question Kunena 1.5.12 Minimum number of characters in post ?
  • C0n
  • C0n's Avatar Topic Author
  • Offline
  • Premium Member
  • Premium Member
  • Only the strongest will survive
15 years 10 months ago #62029 by C0n
I was browsing my kunena configuration but could not find anywere the minimum number of characters for a user to post. I was woundering if its possible to set one because it will stop users from posting replys / creating topics with a small amount of information for example 3 letters "lol".
15 years 10 months ago #62034 by sozzled
C0n: How many months have you been using Kunena? I am fairly sure that you should already be aware of the answer by now: there is no configuration setting in Kunena to do this.
I'm sure that with a bit of your own resourcefulness you can figure a way to prevent users sending short messages if this is a problem. I don't know the technical solution but, then again, I've never encountered the problem, either, with users of my website posting "nothing" messages. I think a lot of this has to do with the "maturity level" of your users; you can help them by asking them to refrain from posting short, nonsense, messages and, if they don't heed your requests I guess you'll have to adopt a tougher line. It's really up to you, isn't it. ;) That's just my opinion and you and others are entitled to disagree with me.
In short, I'm sure you can do this (a simple piece of client-side Javascript to count the number of characters before enabling the Submit button) but I don't know where you would put the function. I'll have to leave that to a K 1.5 technical expert.
  • C0n
  • Offline
  • Premium Member
  • Premium Member
15 years 10 months ago #62036 by C0n
I know but if you cant find it on the forum you might aswell ask the question if still nobody has a clue then get cracking to find the soloution yourself :)
15 years 10 months ago #62037 by sozzled
Fair enough. Well, it looks like you'll need to build a solution, won't you? Sorry I can't help you more.
If you were using K 1.6 then there might be an easier solution but you're not [using that version] and there isn't [a better solution].
15 years 10 months ago #62038 by fxstein
C0n wrote: I was browsing my kunena configuration but could not find anywere the minimum number of characters for a user to post. I was woundering if its possible to set one because it will stop users from posting replys / creating topics with a small amount of information for example 3 letters "lol".
Fair request - currently not implemented. Maybe this or something similar can make it into 1.7
  • C0n
  • Offline
  • Premium Member
  • Premium Member
15 years 10 months ago #62040 by C0n
I was kind of supprised nobody mentioned it before its one of those things that you would expect to be there to stop short pointless post's.
Time to create page: 0.245 seconds
