- Thank you received: 2
Question Question about Adverts using Kunena_msg_x
- bigmike0601
- Senior Member
16 years 4 months ago #52578
by bigmike0601
Question about Adverts using Kunena_msg_x was created by bigmike0601
It works fine for me, but now I want to display only in 1 of my many categories. Is this possible?
16 years 4 months ago #52598
by @quila
Replied by @quila on topic Re: Question about Adverts using Kunena_msg_x
Hi bigmike
all is possible with hack. Open the file message.php and at the and you will find that code
Replace with this
Now publish your module in position "kunena_msg_x_y" where x is number of post (like before) and y is number of category where will show module.
Hope this helps
Regards
<!-- Begin: Message Module Positions -->
<?php
if (JDocumentHTML::countModules('kunena_msg_'.$mmm))
<div class = "kunena_msg_<?php echo $mmm; ?>">
<?php
$document = &JFactory::getDocument();
$renderer = $document->loadRenderer('modules');
$options = array('style' => 'xhtml');
$position = 'kunena_msg_'.$mmm;
echo $renderer->render($position, $options, null);
</div>
<?php
<!-- Finish: Message Module Positions -->
<?php
if (JDocumentHTML::countModules('kunena_msg_'.$mmm.'_'.$catid))
<div class = "kunena_msg_<?php echo $mmm; ?>_<?php echo $catid;?>">
<?php
$position = 'kunena_msg_'.$mmm.'_'.$catid;
</div>
<?php
Hope this helps
Regards
- bigmike0601
- Senior Member
16 years 4 months ago #52861
by bigmike0601
Replied by bigmike0601 on topic Re: Question about Adverts using Kunena_msg_x
@quila,
Thanks so much, I have additional questions though. Using this modified code. Can i still publish other banners on all catergories using the original "kunena_msg_x"?
16 years 4 months ago #53367
by @quila
sorry bigmike for delay
yes you can if you dont remouve old code, just add new code and you can use both position.
Only one thing, if you go in that way in some cat. you'll have two modules published, but you can publish one after first message and other after second.
Regards
Regards
