- Thank you received: 4
Kunena 6.3.7 Released
The Kunena team has announce the arrival of Kunena 6.3.7 [K 6.3.7] in stable which is now available for download as a native Joomla extension for J! 4.4.x/5.0.x/5.1.x/5.2.x. This version addresses most of the issues that were discovered in K 6.2 / K 6.3 and issues discovered during the last development stages of K 6.3
Note: Please go to the Kunena Dashboard after an upgrade so that the Kunena database tables are also updated.
Question Dateformat: dd.mm.yyyy and Timeformat 24h - for Kunena 1.5.4 - 1.5.6
15 years 4 months ago - 15 years 1 month ago #1
by Lintzy
If you prefer the timeformat 00.00.0000 instead of 0000/00/00
and
00.00.0000 instead of for example "00 months and 00 weeks ago"
you must use modified files. The files, you find here to download , are for template default and default_ex only. If you use another template, they will not work and you must edit the files of your template by yourself. Match the files and change them. Upload the modified files per ftp and overwrite the old one. If anything goes wrong with that files, please use the recovery - pack (upload in same way), that are the original files.
The downlaoad for 1.5.6 is here
and
Last edit: 15 years 1 month ago by Lintzy.
15 years 4 months ago #2
by arivor
Replied by arivor on topic Re:Dateformat: dd.mm.yyyy and Timeformat 24h - for Kunena 1.5.4
Thank you very much!!
I wish to be included in the official package.
Arivor
Arivor
15 years 4 months ago - 15 years 3 months ago #3
by Lintzy
Replied by Lintzy on topic Re:Dateformat: dd.mm.yyyy and Timeformat 24h - for Kunena 1.5.4 + 1.5.5
It is planned to integrate this in one of the upcoming versions. Not can say when, but it is planned. I am really appreciating this too
Last edit: 15 years 3 months ago by Lintzy.
- galeforce99
15 years 3 months ago - 15 years 3 months ago #4
by galeforce99
Replied by galeforce99 on topic Re: Dateformat: dd.mm.yyyy and Timeformat 24h - for Kunena 1.5.4 + 1.5.5
Hello, I have applied these files [1.5.4] but they do not work. I use the default template. Is there something else I need to do to change the date format to European?
Last edit: 15 years 3 months ago by galeforce99.
15 years 1 month ago #5
by Lintzy
Replied by Lintzy on topic Re:Dateformat: dd.mm.yyyy and Timeformat 24h - for Kunena 1.5.6 online
New files for Kunena 1.5.6 are
ready to download
Time to create page: 0.418 seconds
