Kunena 7.0.8 Released
Loved Dateformat: dd.mm.yyyy and Timeformat 24h - for Kunena 1.5.3
17 years 1 month ago #20038 by Lintzy
If you prefer the timeformat 00.00.0000 instead of 0000/00/00
and
00.00.0000 instead of for example "00 months and 00 weeks ago"
you must use modified files. The files, you find here to download , are for template default and default_ex only. If you use another template, they will not work and you must edit the files of your template by yourself. Match the files and change them. Upload the modified files per ftp and overwrite the old one. If anything goes wrong with that files, please use the recovery - pack (upload in same way), that are the original files.
17 years 4 weeks ago #23299 by Slotpro
thank you i like dateformat fix , i change all version :kiss:
