- Thank you received: 566
Question JoomFish content element files for K1.5.3
I'd like to hear feedback on JoomFish support. After we have fixed the worst issues, I will add option to enable/disable JoomFish support directly from Kunena Administration.
Attachment kunena_joomfish_1.zip not found
I have a few questions though.
Why no field for translating the new indicator in fb_config?
Why translate the email address of the forum in fb_config?
Why so many translate=0 fields (apart from IDs of course), why not just leave them out?
I just tested Kunena and Joom!Fish content element files (with basic installation of Kunena and added few posts, MAMP environment) and they seem to be working quite nice together. Good work!
I have noticed with one other extension that CE files will be included in the installable extension package and CE files will be installed at the same time as the extension (when J!F is already installed).
With Kunena, IF Joom!Fish is not installed, I think those CE files will not be installed? Am I right here? If yes, users have to install CE files manually. Well, users can find those files from Kunena installable package but perhaps you will add them to your site to be downloaded.
The reason I post this is that I want to add Kunena CE files for Joom!Fish into Joom!Fish SVN at JoomlaCode. See
www.joomfish.net/forum/viewtopic.php?f=21&t=4542
Most probably you will keep us posted here if there are any changes in those CE files.
regards
Harri
J!F forum moderator
seems like it works, at least with categories. :silly:
- balaevolve
is working Kunena with joomfish.
i need your feedback why bcoz i'm going to implement.
pls help me.
Translating configuration (offline message, board title etc) and posts works only with Kunena 1.5.3+. There were also many places where translation didn't work earlier.
Content element files are not automatically installed because of JoomFish support is not ready. It should work, but it's not easy to use. I'm currently waiting for a response from JoomFish team to make better integration.
If someone wants to work with content element files -- please do so and post your work into this thread.
- spacereactor
- Senior Member
- Thank you received: 1
just to let you know I installed the content elements and works just fine for translating categories. Great job.
Any idea how to translate for example the menus, or words like ''total users'', ''members'', the bottom bar for example.
Is there any solution for this?
Many thanks
Alexander
