Question Entry order not sequential after deletion of some entry's
So postings are order now (for instance)
- 11 hours, 12 minuts ago
- 18 hours, 34 minuts ago
- 10 hours, 9 minuts ago
- 10 hours, 5 minuts ago
- 2 hours, 53 minuts ago
- 9 hours, 47 minuts ago
And not only in the topic where entry's were deleted, but also in other topics with reply's after the deletion.
Any help is welcomed
Version Joomla 1.5.22
Version Kunea 1.5.12
Community Builder 1.2.2
Uddeim 2.0
Without a lot more information I don't know where we should begin in order to understand or explain what might have happened. Has this happened before? Does it happen a lot? Has it only happened once? Do you have a backup of your website before the problem(s) happened?
You're using an out-of-date version of Community Builder. Please update it.
Sounds like you may have a potential issue with your database. Have you checked? Do you know how to look for these kinds of things? For how long have you been using Kunena? Have you considered the benefits of the support that you will obtain by upgrading to K 1.6.1?
It has happend before, but it's not our policy to delete entry's, but it happened every time i delete messages (so it happend three times). I tought it might have to do something with the sorting problem of joomla 1.5.22, but even the quick fix for 1.5.22 didn't work.
I have a backup of the website before the error occured first, and checked it to the current, but nothing changed. Except for the update to 1.5.22, but the first time was just before the release of 1.5.22. And i just updated cb... thanx for the heads up
The forum was updated from joomlaboard, through al the fireboards, to Kunena. And before that it was a bbphp board. That's how long we have been using it. I'm considering updating to 1.6.1, but I saw this problem first
I know a bit about databases, but no idea how to check for errors in the fb tables!
But i'm still worried about the original problem!
I see that there is an option in the new form for the configurationfile to publish here, is that what you ment?
