Question [Topic closed by moderator - assumed resolved] 1.5.11 RSS in IE and Fire fox do not work
16 years 7 months ago - 16 years 7 months ago #45297 by larsh
I am using Kunea 1.5.11 with Danish language files. Works fine except that feeds start with the UTF-8 "byte order mark" repeated twice (i.e. bytes ef bb bf). It bothers services like Google Reader and FeedValidator.
If I remove the file kunena.rss.php I end up with BOMs only. Following vague ideas and realizing that _ISO wasn't set, I have tried including DEFINE('_ISO','charset=iso-8859-1') and DEFINE('_ISO','charset=utf-8') both in kunena.rss.php and in the language file kunena.danish.php. No combination made any difference.
Any help is appreciated,
Lars
Last edit: 16 years 7 months ago by sozzled. Reason: minor spelling edit in subject
16 years 7 months ago #45299 by xillibit
Can you please give a link to your rss feed to look at this ?
thanks
16 years 7 months ago #45304 by larsh
Sure, thanks, www.dsmmr.dk/forum/fb_rss?no_html=1
I didn't notice problems with other feeds on the site.
16 years 7 months ago - 16 years 6 months ago #45395 by williamhystevens
Starting in 1.5.11, did not use .10, my RSS feeds see to work but do not render in IE or FF.
XML Parsing Error: XML or text declaration not at start of entity
Line Number 1, Column 2: <?xml version="1.0" encoding="utf-8"?>
If I do a view source on the page all of the data is indeed there just does not render.
I used outlook to verify that external readers are working and they are.
env:
Joomla 1.5.15
Kuena 1.5.11
php 5.3
mysql 5.1.x
SEF: on (mod_rewrite)
Cache: off
Last edit: 16 years 6 months ago by sozzled. Reason: Topic closed
16 years 7 months ago #45408 by williamhystevens
So I removed..
echo "<?xml version=\"1.0\" encoding=\"utf-8\"?>\n";
From
kunena.rss.php
and all is good now.
