Question [Topic archived by moderator - assumed resolved] CAPTCHA problem
Whenever I'm shown the CAPTCHA code it is an non-exsting image. In IE it appears as a red cross and in FF it doesn't appear at all.
In the HTML-source code the image src is listed as:
...path.../index.php?option=com_kunena&func=showcaptcha
Opening that URL in the browser displays this (faulty syntax?):
ÿØÿà�JFIF������ÿþ�>CREATOR: gd-jpeg v1.0 (using IJG JPEG v62), default quality ÿÛ�C� $.' ",#(7),01444'9=82<.342ÿÛ�C 2!!22222222222222222222222222222222222222222222222222ÿÀ�<and so on...>
What's wrong??!
EDIT: there are captha solutions availible on JED joomla extensions directory that can be used for registrations though
personaly i dont use captha i use registration vaildator 2 from the JED site
???captha has never worked on K.1.5x series of kunena, hopefully they will have fixed that in K1.6 when its released
@rojo
In K1.5 exist captha system but show only if you are using forum for Public Read/Write.
What is your configuration for Public Read/Write option??
P.S: url should be ..path.../index2.php?option=com_kunena&func=showcaptcha
I've installed the latest Kunena version. Why would the path be wrong? And how should I fix it? Besides the URL clearly shows some kind of jpeg-signature. Why is the image faulty?
